跳转到主内容
Repair guides and disassembly information for Google's Pixel 4 smartphone, released in October of 2019.
44 个问题 查看全部
My pixel 4 wifi will not connect unless I'm close to the router
Hello
I changed the screen with the body to my pixel 4 because the original screen broke. After I fixed that the phone won't connect to wifi. I noticed the the coaxial cable on the phone was damaged so I bought galaxy s8 cable from ifixit, because they didn't have pixel 4 cable. I replaced it but the problem remained the same. I did all the troubleshooting steps online and still didn't fix the problem. Any suggestions to how I can fix the issue?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi,
Check that the WiFi antenna cable is securely connected at both ends.
Here’s the iFixit Google Pixel 4 Motherboard Replacement guide that may help you.
One end of the antenna cable is shown in Step.34 of the guide
It can be seen in the image with this answer. It is the grey (white?) cable with the silver connector just below the orange flex cable at the bottom and it goes up past the left side of the battery
这个答案有帮助吗?
得分 1
1条评论:
Thank you! I replaced battery and I may have dislodged that connector by the battery. I'll have to look at it one more time to see if that's the case.
完成的
添加一条评论
添加你的答案
Ayad King 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 9
总计 328
