跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
137 个问题 查看全部
Battery drained rapidy fast, phone heated up when charged.
The night before I put my phone in the charge, slept, and woke up 8 hours later to find the phone super hot. I turn it on and it has 10%, then 9% ,then 8%, decreasing by 1% around every 5 seconds. My phone usually is slow but this time it’s noticeably slower.
My phone shuts down and I put it in the charger for maybe 15-20 mintues. I come back and it’s at 15%. The temperature is usual, maybe a bit warmer (32C),.The battery started to drain somewhat fast, then slowed down to the usual. Performance started out slow, but now it’s the usual.
What happened to my phone? Should I check on the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Be very careful with it. Check to see if the phone is puffed up. If it is in a case CAREFULLY remove it and check. I keep a glass oven safe casserole dish handy to drop the phone in and run outside. If the battery punctures it will heat up and catch fire. If it is puffed up stop using it and replace it ASAP. If not never leave it unattended while charging until you are positive the battery is not defective. You may have just had a lot of apps running in the background that heated the phone. I have left Pokémon Go on and it heats the phone fast and hot. Bottom line, it is better to be safe than have to deal with a fire.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dinidu Samaranayake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 34
