跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
Why won’t my controllers or USB ports work
My wireless controller will not sync with my console with or without USB connection. The synch button on my console doesn’t work either. I purchased a corded controller to see if that would bypass the problem. I have tried all of the troubleshooting problems and have discovered that the USB ports and wireless/wired controller work after a hard shutdown. The problem is the second time I turn on my console it happens all over again. So it seems unless I find a fix I have to hard kill my console every time which you can imagine is annoying given I can’t resume gaming where I left off and the boot time is MUCH longer. I can’t find anything that relates to my problem and the research I have done would make me believe Microsoft doesn’t support this kind of repair.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi David,
So this would be either a motherboard issue OR software issue. As you said that it is working after a hard reset, it do sound like a software issue. Did you tried to reinstall it completely?
这个答案有帮助吗?
得分 1
6条评论:
I had performed a factory reset that kept my games and apps but that didn’t help
完成的
Alright. I recommend to do a full restore. So that everything will be removed and that you need to start from scratch (format and install). Perhaps that will resolve it.
完成的
Full factory reset did not resolve issue. Not sure where to go from here. I’d rather no have to full shutdown every time I want to log in and then wait forever for game to boot because I can’t resume where it left off. Ugh
完成的
Hmm, weird. Perhaps you need to replace the front panel board. It's related with the sync button.
完成的
@dan0 that is a great thought. Would the WiFi card have something to do with it as well?
完成的
显示更多的1条评论
添加一条评论
I have this problem with my Series S. I think the board needs to be replaced. Uhh 🫠😒
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 163
