跳转到主内容
Step-by-step guides for canister, robotic, and upright vacuum cleaner repair.
1037 个问题 查看全部
My vacuum cleaner sucks the dirt up but blows it out the back , I put
Why my vacuum cleaner blows dirt out the back after it sucks the dirt up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Can you please add some more information about the problem, like where is it coming out etc.?
It would also help if you added pictures. 在已经存在的问题里加入图片
完成的
First of all, is it a bagless vacuum cleaner or does it have a dust collection bag? If it has a dust collection bag fitted, then it could be ripped, not fitted correctly or the wrong type for this model. Most vacuums also have an air clean up filter element on the air outlet side, this maybe missing or damaged.
完成的
添加一条评论
1个回答
As stated in the comments, would be helpful to know the make, model or type of vacuum cleaner. One that uses a disposable bag or one that has a see through canister that you empty out when full. Also when did this problem start, after a dirt disposal operation, bag or filter change or change of attachment, pipe, nozzle etc.? More information needed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shirley Gauthier 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 19
