跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
I've just replaced the batter in my iPhone 6s, but the new one won't c
new battery won’t charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Reinstall the old battery and see if it charges. If it does you have purchased a faulty battery.
完成的
添加一条评论
2个答案
Run the new battery until it is completely drained. Then, try charging it up. If this doesn’t resolve the issue, then the replacement battery is probably faulty.
这个答案有帮助吗?
得分 0
添加一条评论
Before your phone charges the battery, it needs to communicate with it in order to know its condition (how much charge it has/needs, for example). But in order to do this, the battery has to have enough power. If the battery is completely drained for whatever reason, stayed on shelf for too long, for example, then this process can’t start. This doesn’t mean the battery is faulty, only it needs a jump start.
The way to do it is pretty simple: take it out of the phone and use a separate DC power supply to charge it. Check and adjust the voltage, monitor the current to make sure you don’t over charge or cause explosion. I usually don’t want the current go beyond 500mA.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jane McDermott 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 30
