跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 not charging past 80% after battery replacement
The macimum capacity of my iPhone battery dropped to 86% so i decided to have it replaced (not by Apple). With the new battery, it wouldnt charge past 80% unless i leave it on charge overnight ( optimised charging was turned on). I turned optimised charging off and it still wouldnt charge past 80% during the day. I took it back to where the battery was replaced and they change the battery. The problem still remained.
I took it back and they put my old battery back in. Now the old battery will not charge past 80% unless i less it on charge overnight.
If anyone can help me with this please let me know.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would maybe try a factory reset next. I’m wondering if optimized battery charging is having an issue. Do you use a lightning cable or wireless charger?
这个答案有帮助吗?
得分 1
1条评论:
Yes, i use a lightning cable. I have not tried factory reset yet.
完成的
添加一条评论
添加你的答案
edem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
