跳转到主内容
Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
17 个问题 查看全部
Why is there oil on my spark plugs like alot my lincoln town car
i changed my plugs cause i had a misfire an when doing so had a lot of oil on my plugs an coil packs 2007 town car 4.6
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like you might need a new valve cover gasket. Check to make sure valve cover isn't cracked. If it isn't then the gasket is most likely the culprit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shawn 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 7
总计 141
