Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
shawn @shawn88
声誉积分: 1
发帖于: 2021年4月10日
i changed my plugs cause i had a misfire an when doing so had a lot of oil on my plugs an coil packs 2007 town car 4.6
这是一个好问题吗?
brandon k @brandon_k
声誉积分: 2.9千
7
6
5
发帖于: 2021年4月11日
Sounds like you might need a new valve cover gasket. Check to make sure valve cover isn't cracked. If it isn't then the gasket is most likely the culprit.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 134
