跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
connector #7 damaged on LB
I seemed to have mangled the #7 connector on my logic board and now have no signal. is there a way to "bypass" this mini-coax connector and solder a wire(s) directly from the #7 flex cable or even antenna dock, directly to the logic board?
thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The best way is to remove the damaged connector and replace it with a new one. There are 2 connections that need to touch the board, and 1 wire will not suffice. It is much easier to replace the entire connector than to try and fuss with a temporary fix. You're going to need a fine-tipped iron, a microscope, and patience if you plan to try this. Or send it to a professional to do.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
39 Stripes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 956
