跳转到主内容
加入维修社区 - 创建账户
50" Plasma TV by Sanyo released in 2007.
My TV turns sound works but no picture
Sanyo dp50747 TV has sound but no picture
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My TV had a backlight issue that actually managed to fix itself after about a year. I have no idea what caused it originally, but I am guessing some kind of short developed.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @librado67 ,
Here’s the no video troubleshooting flowchart, from the service manual.
This may be a good place to start testing what the problem is. There a full schematics in the manual which should also help.
Hopefully a start
这个答案有帮助吗?
得分 1
添加一条评论
Try checking the screen closely with bright images (if it is possible to get one displayed) and/or try shining a light on the screen. If you can make anything out on the screen, the backlight has probably failed. If, no matter what you try, you can’t see anything, the display itself has probably failed or disconnected. It is best to consult a disassembly guide or professional to fix these issues unless you know you can do it yourself and have the right tools.
这个答案有帮助吗?
得分 0
2条评论:
Hi @michaeld2 ,
This TV model doesn't have backlights to light the screen as it is a plasma TV.
There are phosphors in the screen that light up when the current passes through them
完成的
Good to know. I'm not the most knowledgeful person when it comes to electronic functionality.
完成的
添加一条评论
添加你的答案
Librado Salinas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 391
