跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Main back camera works fine, but no 2x camera and no Flash
The camera app opens fine and works well at 1x zoom, but the telephoto 2x mode cannot be accessed when I press 1x, no matter what I try to do on the software…. Also, the flash doesn’t work, as well as the flash light. Any ideas on what I can do, or what might be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The x1 and x2 are two separate cameras, perhaps the x2 unit is faulty. You would need a complete new camera unit as you cant just replace one of the cameras. The flash is attached to the volume buttons, mute switch and power button. If they are working then its just the flash which is faulty and the flex will need replacing. I hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KAVA KONNECT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 34
