跳转到主内容
The Town & Country was redesigned for the 2001 model-year, using the Chrysler RS platform and initially only available in long-wheelbase (LWB) form.
25 个问题 查看全部
I can't find my cabin air filter, in 2006 town and country
i can’t find my cabin air filter under the passenger dash 2006 town and country LX
Update (04/01/2021)
I can’t find my cabin air filter in my 2006 chrysler town and country LX. It’s not under the passenger side dash, neither behind the glove box
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I canot find cabint air filtter for a/cin town and country 2006
完成的
添加一条评论
5个答案
最有帮助的答案
Hi,
According to the 2nd video Locate cabin air filter in this link there is only a cabin filter if you have the automatic climate control feature.
这个答案有帮助吗?
得分 1
添加一条评论
in the passenger side under the dash between the center and glove box you will see a long black 2" x 8" with a nob the center turn to unluck
这个答案有帮助吗?
得分 0
添加一条评论
Not all chryslers have a filter I know unbelievable huh it can only be one of 2 places behind the glove box or underneath the glove box the one underneath is very long and a pain to reinstall if youu don't hv a filter and your cars air smells from your air conditioner being turned on my suggestion is to get a can of lysol and spray some into the air conditioner intake located on the outside of the vehicle at the bottom of the windshield and see if that helps
这个答案有帮助吗?
得分 0
添加一条评论
there is no hvac filter
这个答案有帮助吗?
得分 0
添加一条评论
Under the dashboard next to the instrument panel is a black plastic panel with a slide lock. It’s not very easy to spot because you have to get down low and look up…but it’s there. It’s about one and a half inches wide and several inches long. Pull the slide lock towards the back of the vehicle and then pull the panel down. The slide lock pulls out very easily. It was not easy to spot. I looked and looked and almost gave up when I finally saw it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vernellsmith07 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 79
总计 1,424
