跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Is the ear piece filter necessary?
So this week I replaced my Iphone 4 screen with a new one after cracking my old screen. After looking at the new screen I realized that the ear piece looked different. When I compared it with another phone I saw that, what I am calling the filter, was missing.
It is the metal, mesh screen behind the ear speaker opening. ANyway, is this piece necessary? Everything seems to be working fine it is just sort of an open hole into the phone which scares me. Further if this is a potential problem can I replace this?
THanks for the help, this site saved me some cash big time!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
最有帮助的答案
I found a cheap workaround to avoid taking the phone apart and posted my solution here.
这个答案有帮助吗?
得分 2
添加一条评论
I wouldnt guarantee it but I dont think its vital to the functionality to the phone. I'd say at best it filters any dust and debris that might go through that hole into some sensitive hardware inside the iphone. It might be worth replacing because down the road you might wonder why you cant hear anything when people call.
这个答案有帮助吗?
得分 1
添加一条评论
The problems won't be immediate, but the dust going inside the phone is bad. Lint can hold moisture and bridge connections...causing your phone to not work well, or at all.
Why don't you cut the mesh down and try to slide it into place? It will still look off, but you will have some protection- that is unless you would prefer doing it the right way and disassembling the phone (look at it as an investment).
这个答案有帮助吗?
得分 1
添加一条评论
I found that leaving it off resulted in sounds being really buzzy when talking to someone. It's best to leave it on for dust protection as well as having a good sound.
这个答案有帮助吗?
得分 1
添加一条评论
As above really, it is advised to put it in there purely to protect the insides of the phone from dust/lint. It is easy to fit after you get the screen off just time consuming to get it all apart.
这个答案有帮助吗?
得分 0
添加一条评论
Whoops forgot to install the little earscreen?......myself i wouldn't worry about it, just look at your home pc and how much garbage gets in there. Only prob i can see is if the little fuzzys get in there after about 3 years of buildup and u decide to use your phone in a wet sauna.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
redacted 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 14,262
