跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
SSD no longer recognized after Disk Utility erase
I have a 15” late-2016 MacBook Pro that I had used daily since I bought it in 2017. I was trying to wipe the drive as I had just sold it online, so was following Apple’s online guide to preparing it for sale. https://support.apple.com/en-us/HT201065
I got to step 7 and followed the instructions here to erase the drive. https://support.apple.com/en-us/HT208496
When disk utility finished, it restarted and showed a circle with a line through it. Being somewhat tech savvy, I booted into internet recovery but found in Disk Utility there was no SSD listed. So I made bootable copies of Big Sur and High Sierra and loaded Disk Utility through those and still no device or volume listed. I tried using Disk Utility Terminal commands to see if anything was listed, and nothing was listed that should have represented the 512GB drive.
I can’t figure it out.. and the techs at Apple are bemused. Apple is now saying the SSD needs to be replaced. I literally followed their instructions, and now they’re asking me for $680 to fix it!? Is this a known problem with old Apple SSD’s, APFS, and Disk Utility? Does this sound familiar to anyone? TIA!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
When you access Disk Utility from Recovery Mode, make sure Show All Devices is selected from the View menu. Also, can you post a screen shot of the results of running the following Terminal command: diskutil list
完成的
Hi there. When made to 'show all devices', it still did not show the drive. Unfortunately Apple has the laptop now, so I can't post the diskutil list. But even in that, it showed only the boot disk, and a few other small drives, sometimes listing as much as 16-19 disks, but they were only about 50kB each. Not the 512GB SSD.
完成的
添加一条评论
1个答案
Might need to be repartitioned on another desktop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zadefaraj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
