跳转到主内容
Bose's first wireless noise-canceling headphones, praised for their industry-leading noise cancelation technology and comfort. Released in June of 2016.
54 个问题 查看全部
One of the earpads can rotate a full 360 degrees where it used to stop
As stated in the title, one of the earpads on my Bose QC 35 II headphones can rotate a full 360 degrees of motion. It does not make any clicking sound in doing so and rotates smoothly without any extra force applied. The other one has limited rotational ability. Is there some way that I can fix this myself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
only real way since i cant find any kind of schematics for this thing is to tear it down your self. carefully and look to see if there are any pins or things that are on the right side that the left side or vice versa has.
is so youll have come come up with a way to replace it. (manufacture a new pin or something)
best bet is to check ebay and see if theres a person that either has a dead unit for CHEAP or someone that sells the headband plastic arch piece
https://www.ebay.com/itm/333633776879?ch...
the only other alternative is to send it to bose so they can replace the entire headband.
good luck!
这个答案有帮助吗?
得分 2
1条评论:
Definitely sounds like a solid procedure. Thank you!
完成的
添加一条评论
添加你的答案
Jacob Andersen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 624
