跳转到主内容
加入维修社区 - 创建账户
2000年8月发布的卡西欧科学计算器。型号标识为 FX-115MS。
Why won’t it use the battery?
I know the version I have (Casio fx-115 ES Plus 2nd Edition) is solar powered, but I thought that it could at least store power or use it’s battery when it’s not directly under a light source? As of now, it won’t turn on unless it’s directly under a light source…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It is possible that this model doesn’t have a battery. Many calculators are 100% solar powered.
However, if this model does have a battery, the battery is probably dead and needs to be replaced. These batteries are usually not rechargeable even though there is a solar panel. Over time, the battery will die.
If there is a battery compartment or cover on the back, then it is simple to replace the batteries. Otherwise you may have to take the whole thing apart (assuming it has a battery in the first place).
Hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
yasmeen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 1,550
