TV Philips 49PUS6101/12 won't turn on
Hello, i want to ask you about my problem,
TV won’t turn on, i repaired backlights, still no screen, then I replaced Power board, New Power board started to click, now what? Im in the end, i dont know what to do next.
Im learning electromechanism for 3 years, so im kinda new to this, Please can you help me? Thanks.
pictures might help narrow in on a problem. try taking some pictures of the board and all that.
由 Logixal 完成的
Did you measure the input and output voltages on the PSU board before you changed it? Do you have normal readings on standby and at the LED driver?
由 honakrisi 完成的
@honakrisi
Sorry, i didn't write, what i did...
But, i found that when the power board clicks, it means somewhere is shortcut, so i unplugged boards from the end till it stopped click, It stopped at AV Main board.
Do you think thats the wrong part? Should i try to repair it? or buy new?
Thanks for answer.
由 The Vampir 完成的
the easiest would be to just replace stuff. but might be more expensive that way
由 Logixal 完成的
