跳转到主内容
Windows has suddenly started freezing and restarting. is it the eMMC?
So today windows 10 had started disconnecting from the internet, then freezing and rebooting (no bsod) could it be a problem with the systems eMMC drive? (I have tried reinstalling windows multiple times and it has not fixed the problem)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
  • Does the problem onlty occur if you try to connect to the Internet? If so, the problem could be your Wi-fF card. At 2:33 on the video below the Wi-Fi card is slotted in at the top near the yellow CMOS battery. Just disconnect it and then connect an Ethernet cable to the Ethernet port on the laptop and the p[ort on your modem/router? Internet work now without a crash? Yes? Then the Wi-Fi card is defective or its driver is incorrect or corrupted. Generally most problems are software related or the BIOS needs updating. Sometimes Windows uipdates can cause problems.
  • https://www.youtube.com/watch?v=ifsPLgSU...
  • The drive is upgradeable, IF you have the M2 model. Do you?:
  • https://www.crucial.com/compatible-upgra...)
  • with a PCIe M.2 2280SS SSD drive.
  • Open it up and take a look:
  • https://www.youtube.com/watch?v=1P4raZPm... (turn volume down)
  • Let us know how it goes. There are other possible steps to take.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dylan Bevan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 99
