跳转到主内容
Self-priming automatic electric pumps with helical gears, produced by Marco.
27 个问题 查看全部
Bleeding the pump every few days?
Why do I need to constantly bleed this pump every few days.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi @grandbanks ,
What is the model number of the pump?
Maybe @teof will know the reason for this
Be a bit patient for a response from him as this is a world wide forum and different time zones come into play
Moderator
完成的
The top plate rubber coating is damaged and pitted so the orang leaks.
Waiting for someone from Marco to reply with warranty or replacement parts.
Pump is 20 months from purchase. Warranty is 2 years.
Model UP6/E
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @grandbanks, bleeding the pump every few days is not normal, you may have a problem somewhere!
Please check if:
  • The inlet hose is not “cooked” (old, yellowish and hardened) and, in case, cut a few centimeters (inches) of the part that is over barbed hose fitting. Often, after some time, this hose gets hard and lets the air in, leading to the need to prime again.
  • The inlet hose has a hose clamp to keep it in place on the hose fitting. Failing to do this gives many problems.
  • The filter has the o-ring correctly placed and/or the plastic is not cracked. If the filter lets air in, you may often lose the priming.
  • the filter and fittings are properly screwed to the pump
  • if you have multiple tanks, check that the ball valves on the inlet are not letting air in. You could try to bypass the valve and connect directly to a tank, and see if the pump loses prime again.
  • if you have cleaned the gears and unscrewed the top plate, check that the o-ring that seals the top plate is properly placed.
I hope this helps! If not, feel free to add more information :)
Best,
Matteo
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maury Bonas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 184
