跳转到主内容
The Asus X553MA-BPD07051 is a laptop designed and made by AsusTek Computer Inc. This laptop, released in 2015, runs Windows 8 and can be upgraded to run Windows 10. It is a good laptop for everyday use.
4 个问题 查看全部
Why my computer is not turning on
I have a laptop that suddenly stopped working no fan but the power light is on so i tried a different charger still. i opened the computer removed the battery made a hard reset still nothing the strange thing is when i put the ac cable the cpu begins to heat up even though nothing else is happening
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @faezajackson ,
Here’s a link to the Asus X553MA repair guide that may help as it appears that the problem is on the motherboard.
The guide details the power on sequence (in both modes, battery and AC) and gives the voltage measurement locations for each step in the power on procedure.
It may come down to having to go through the sequence and find out where it fails to find out what the problem is.
这个答案有帮助吗?
得分 0
1条评论:
I will definitely try that
完成的
添加一条评论
添加你的答案
Faeza Bakr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 133
