跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Just got iPad Air battery repair kit and can't get the screen off
tried using the iOpener, blow drier, suction cup and I can’t get the screen up. should i use the edge tool to bend the metal out a little to get under the glass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks! I'll give that try
完成的
添加一条评论
1个答案
已选择的解决方案
The glue on older iPads can be dried out and it can be really strong. You need a lot of heat (80 degrees Celsius) to soften the adhesive. It can help to apply a few drops of IPA or rubbing alcohol along the sides, it wil soften the adhesive as well. Do not pry too hard, if it does not lift easily you will damage your screen. Life hack: back in the days when I did not have a heat mat I used my party grill with a flat plate on low heat. Just keep it below 100 degrees to protect the screen and plastic parts. The iOpener also works well, but the iPad’s case dissipates the heat really quick. It can help to heat the entire iPad to help the iOpener a little.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 70
