跳转到主内容
Repair guides and disassembly information for the 2017 edition of Razer's 14-inch Blade gaming laptop.
15 个问题 查看全部
Why won’t my laptop power on?
I have removed the battery due to it puffing up. Although my laptop is plugged in and had previously booted up with only the power cable, it is now showing no signs of life when attempting to power on. The charger and outlet are both good. What is likely the cause of the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If your laptop won't power on, even when it's plugged in could have a faulty power supply, motherboard, video card or RAM. Ensure the plug to the power cord is plugged into an outlet and to the computer. Check the laptop's battery and power connector to make sure the connection hasn't come loose.
There are some troubleshooting tips that you can try for fixing laptop/computer won’t turn on.
这个答案有帮助吗?
得分 0
添加一条评论
did you ever somehow fix this? thank you!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dara baradaran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 656
