跳转到主内容
The Acer Chromebook 14 is a Chromebook with a 14" display, released from Acer in 2016. Model Number: CB3-431.
12 个问题 查看全部
Can I change the ssd card on this to add more storage on it?
I have a Acer chromebook 14 and I was wondering if I can change the 32 ssd for a 256 ssd to install windows 10 as a virtual machine on it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What is the exact model? Have you opened it up to have a look? Does it have an SSD or M.2 drive installed? If it does. . .maybe.
完成的
The specific model is cb3 431 c3ws .
完成的
@mrfixer2011 Found a photo of the board... Soldered.
完成的
添加一条评论
2个答案
已选择的解决方案
If you can change the motherboard with one that has a different storage limit you can change the storage on it.But you need a USB recovery tool from the Chrome recovery utility on the web store since you wont have a os.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Most Chromebooks use eMMC, so not likely. If you see a M.2 slot it might work, but it will likely always require keeping the base 32GB of eMMC if it can be done, in addition to the add-on SSD.
More than likely, it will be fixed (non-upgradeable) eMMC. Outside of a few like the Acer C710 (mSATA) I’ve never seen a modular SSD in a Chromebook.
Edit
Yep. It’s soldered.
这个答案有帮助吗?
得分 1
4条评论:
Thx.I decided instead I could put it on ebay and buy and buy a asus chromebook flip c436.Does that one have a ssd.
完成的
@mrfixer2011 Also eMMC.
完成的
Oh Really.Then how do you explain on Best Buy and Amazon that they have different storage limits on it.
For asus chromebook flip c436 best buy
https://www.bestbuy.com/site/asus-chrome...
For asus chromebook flip c436 amazon
https://www.amazon.com/ASUS-Touchscreen-...
完成的
@mrfixer2011 Different boards.
完成的
添加一条评论
添加你的答案
Arvin Klair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 277
