跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2012 年推出的第一代 7.9 英寸 iPad mini,拥有 16、32 或 64 GB 存储容量,搭载 A5 处理器。
Ipad Mini Won't Respond.
The Mini Ipad does not respond at all. It worked perfectly until the home button was unresponsive. Then, the home screen became like a “glitch” when I turned it back on after I turned it off to do work outside. I can’t press the pass code or anything to get in. Every time I turned on the home screen, it then “glitches” and fades to black. Somehow, the home button was working again but only for the power reset. I then hold both the power buttons to reset it but it then made it worse. I turned it back on, the Apple Logo appears, and then it fades away like a “glitch” to a black screen. I even tried doing it with a charger on as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What happens when you do a soft reset (hold home button & power simultaneously)? If that doesn’t reset it, can you connect to a Mac & restore it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Blue Dude [G] 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 21
总计 230
