跳转到主内容
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56 个问题 查看全部
How long does it take to charge my newly installed battery to 100%
Just replaced my battery. Eazy peazy. Ifixit directions say to charge to 100% and to keep charging then for 2 more hours. No problem, except - how do I know when it is 100%? How many hours does it take? Some people say 2. Some say 24 hrs. Help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @shaliajojo ,
The charge time for a battery will depend on how much charge it had in it before it was started to be charged. With some it may take up to 4-6 hours if the battery was old and nearly completely discharged but taking nearly 24 hours would indicate either a problem with the charger, the charging circuit or the battery.
Not sure with your model but doesn’t the charge light on the laptop change colour from orange to white when it is fully charged?
When the battery is fully charged, check its status by creating a Win 10 battery report and compare the Design Capacity versus the Full Charge capacity to make sure that the battery is OK. They should be nearly identical in value
这个答案有帮助吗?
得分 3
添加一条评论
The battery meter on the laptop should show the current percentage. It may also show estimated time until full charge.
这个答案有帮助吗?
得分 2
1条评论:
So funny - I didn't think I was "supposed" to turn it on when I was charging. TY
完成的
添加一条评论
添加你的答案
Shalia Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 54
总计 820
