跳转到主内容
The TravelStar DJSA-220 is a 2.5-inch form factor hard drive released by IBM around the year 2000. It has a capacity of 20 GB.
3 个问题 查看全部
What computer does this hard drive go in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @jpicking85
That is a PATA HDD.
So it will fit into any PC that has IDE connectors on the motherboard and also a spare 4 pin power cable to connect to the drive.
If inserting in a desktop and not a laptop you will also need a 2.5” to 3.5” caddy so that it can be physically mounted in a drive bay
It is outdated now but you can get IDE HDD to SATA adapters that will allow you to connect to any PC that has the sata connectors.
Here’s a link that may help.
这个答案有帮助吗?
得分 1
添加一条评论
It will work in any laptop with an IDE interface. Some laptops may have trouble fully addressing it without a 3rd party tool to split the partitions on the drive, mainly 28-bit LBA machines which cap at 128GB.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jonathan picking 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 100
