跳转到主内容
Released in May of 2019, the Xbox One S All Digital Edition (model number 1681) is a revision to the Original Xbox One S (released in 2016). This model of Xbox One S ships with no Blu-Ray Disc Drive (thus there is no disc slit at the front), exclusively providing downloadable and streamable entertainment.
23 个问题 查看全部
My Xbox One S doesn't send a signal to the television
My Xbox One S (All Digital) does not send a signal to the television, I was downloading a mandatory update and when I finished I started to download a game that I bought online, everything was fine, the update did not present any problem but then the download of the game crashed so i rebooted the Xbox but it no longer works.
My console sometimes turns on and then not, if I want to turn it off I have to press the power button for a long time. My TV's HDMI says “This source is not connected. Please check the connection again ”. I have all the cables connected and have changed them to test if they all work. But that already worked before. Another thing that I need to record is the wireless controller, which blinks and stays like this as if waiting for something.
Link to the video of the problem my console (Youtube): https://youtu.be/lXsKyQZ939o
I hope you can help me, some have told me that she tries to format it but obviously I don't want to do that. Thanks for taking the time to read!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I think that the update changed your console’s display settings (most likely reset them) so you may have to change them.
这个答案有帮助吗?
得分 0
2条评论:
It may be and it may not, in my case I did not see any problem with the update but it may be that I am wrong. But still I can't change the console settings because it won't let me do it. I try as they say to reset the screen settings but nothing happens.
I think I have the problem of the second case that is the most serious on the following page: https://n9.cl/b1bdx
Anyway I will try again, thanks for answering!
完成的
I had to factory reset mine.
完成的
添加一条评论
添加你的答案
alison zertuche 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 45
总计 2,738
