跳转到主内容
Repair guides and disassembly information for the 2017 edition of Razer's 14-inch Blade gaming laptop.
15 个问题 查看全部
Battery Power Not Being Used
So my razer laptop now only turns on when AC is plugged in. The battery level was 95% last month and it went down until today it only has 88%. What can i do to fix it?
Here’s a list of things I tried:
  1. Clean Fans
  2. Plug my charger into a wall socket, not through an extension socket
  3. Format PC
  4. Remove battery connection then connecting it again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @veggieta ,
Create a Win 10 battery report to check the status of the battery. It may be that it is failing and needs to be replaced.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value to see whether the battery is still good or not.
If the battery needs replacing, here’s a video that shows how to do this.
Search online using the battery model number (found on battery) i.e. (insert battery model number) battery to find suppliers that suit you best.
这个答案有帮助吗?
得分 2
3条评论:
I already replaced the battery 9 months ago because it was bloated already.
Here’s a screenshot of my battery report:
https://pasteboard.co/JRbjILh.png
完成的
@veggieta
Does the laptop stay on if you start it on the charger and then once it has fully booted and settled, remove the charger, you didn't say?
If it doesn't then perhaps when the previous battery bloated it may have damaged the battery management circuits on the motherboard.
You would need to find the schematics for the motherboard and start testing why the battery is not supplying the power to run the laptop.
Have you inspected the motherboard for any obvious component damage?
完成的
yes, the laptop stays ON when charger is plugged in, but when i remove the charger it shuts down. I've inspected the insides again and i don't see any burnt components in here.
完成的
添加一条评论
添加你的答案
gabo.janicolo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 467
