After changing the digitizer on Apple Watch 4 touch don't respond
Hello, After changing glass and digitizer on Apple watch series 4 40mm, the touch screen don’t respond.I thought the purchased digitizer did not work so I re-installed the new digitizer but it still does not work.I think the connecting cables were not damaged during the repair. any solutions? Does changing the display flex cable help this problem?This is a picture of the digitizers I bought
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Hi, this might sound silly but did you restart the watch? Sometimes a cheeky restart will fix it
完成的
@pomikoli sure, i tried thousand times but didn't help
完成的
haven't done one
however do they have a seperate screen and digitiser
and I'm guessing you replaced the screen ?
try cleaning the connectors with alcohol?
完成的
@golde They have only glass and digitizer together, no i dont replace lcd screen. i replaced only digitizer.
完成的
@atmx does the old digitizer work
if it does it could be paired to the device
完成的
添加一条评论
