Intermittent crackling sound but speakers work
Replaced battery successfully two days ago. Now hearing an intermittent crackling static sound. The speakers are working fine.
Update (03/02/2021)
Finally got something to upload properly. I can also report the MBP is running hot when I am on a website.
Update (03/02/2021)
I skipped steps 6-46 when replacing the battery.
7条评论
In a very quiet room can you capture the sound and post it here so we can hear it 在已经存在的问题里加入图片
由 Dan 完成的
@danj I reset the fan control to default and no longer hear the noise. The fans are both running normally. If it acts up again, I will record the sound as best as I can and post it. Thanks for getting back to me.
由 Charles Gardner 完成的
@danj The noise has resumed. I recorded it as a Voice Memo but cannot upload it in an acceptable format. Any suggestions?
Can you locate what area of the machine the sound is coming from? The only physically moving component in this model is the fan.
由 Zach 完成的
@chasgardner - Can you convert it to what iFixit supports? Its not very long is it? If it is you'll need to trim it down.
由 Dan 完成的
显示更多的2条评论
