跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
iPhone Xr without TrueTone and WITHOUT Not Genuine Display after reset
Hi there,
I got weird iPhone Xr - it does not have TrueTone option in Settings AND it does NOT have “Important Display Message”.
If it would be replaced - I would have that message OR - if replaced and TrueTone flashed with programmer - I would have TrueTone AND “Important Display Message”.
Any chance you know what is happening?
Additionally Auto Brightness works in my Xr - where in my other iPhone 11 where I flashed TrueTone data from original cracked display - TrueTone works - NO auto brightness - and “Important Display Message”.
Crazy :)
Thank You for helping me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
it is possible they flased the serial number of the screen without the TrueTone data i have accidentally done this when i was rewriting the serial number from the old screen to the new screen as long as you have the old screen it should be easily fixable
这个答案有帮助吗?
得分 0
5条评论:
That would be even more weird.
I got iPhone 11 - purchased LCD replacement - I managed to copy TrueTone with iCopy Plus but I got message 'not genuine Apple screen' - the reason it is weird to me :) because someone managed to copy screen serial number BUT no TrueTone?
完成的
i understand that i use a JCID V1S for screen replacements, you connect the phone before disassembly and you read and write everything to new screen. Then before reassembly you verfiy old screen then new screen to make sure TrueTone, Auto-Brightness, and the phone will not complain about non-oem parts
完成的
I got better question - so if serial number was copied to my NON-genuine screen - and I purchase new NON-OEM screen - I wonder it TrueTone will be restored because data has been copied :)
完成的
iin theory its supposed to it has worked for me so far with no issues TrueTone and Auto-Brightness work and not a single phone i have repaired has had the Not A Genuine Apple Part or IMPORTANT DISPLAY MESSAGE
完成的
also it depends on the manufacture of the replacement
完成的
添加一条评论
The iPhone XR and XS don’t get a non genuine display message they simply just disabled True Tone.
The XR and XS do have the non genuine battery message though.
It wasn’t until the iPhone 11 that they introduced the non genuine display message.
Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 76
总计 1,826
