跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5712 个问题 查看全部
Horizontal lines on the screen after replacing the battery.
I replaced the battery of my 2015 iPad Pro (A1652).
Everything is working great but the top 2cm of the screen are now broken and it’s only showing horizontal lines.
At first, not even the touchscreen was working but I fixed it by disconnecting and connecting it again.
That makes me think that maybe the lines on the screen could be a connection problem between the screen and the logic board instead of a broken screen.
Can somebody with actual knowledge tell me if that is possible?
I was extra careful when I was detaching the screen (I even used a hair dryer) so I’m pretty sure that I did not break it… Although I’ll trust you if you tell me that I did haha.
Maybe I overheated the screen? Idk… send help :’(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
the LCD’s for ipads are really easy to break, as you have to remove the glass and that could damage the LCD. It’s rare that a battery could cause lines, but it is possible. If that’s the case, just disconnect and reconnect the lcd a few times. If that’s not fixing it, it’s likely you damaged something on the LCD.
Have a good day
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juanpi Briones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 230
