跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
SD Card Door Won't Stay Shut
The little flip up door that holds the SD card in place won’t hold the SD card in place.  Gorilla tape only works so long and not very well.  Is there a fix for that little annoyance you can suggest?  The device works perfectly fine otherwise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello Gregory,
I would suggest maybe duct tape and put a lot of it. That should help keep the door shut. I cannot find a way to replace the door but if you want, I am not saying to do it. Pull out the flap and put duct tape over the place where the door used to be. If that does not keep the SD Card door in then I am not sure
Happy Fixing!
-Javen
@tacofixes
这个答案有帮助吗?
得分 0
1条评论:
I was hoping to not have to just add more tape. thanks.
完成的
添加一条评论
添加你的答案
Gregory Redick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 133
