跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
147 个问题 查看全部
Replaced battery and won't turn on unless connected to charger
I changed the battery and now it won’t turn on if it’s not connected to the charger. Once it starts I can unplug the charger and the status indicator will change to battery after 10 seconds or so.
SMC reset done twice and still no change.
Any idea what could be wrong? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Double check if all the connections, especially the battery connection (MacBook Air 13 英寸 Retina 显示屏 2018 年末电池更换) are seated correctly in their sockets. If all the connections are good and nothing is damaged while repairing your MacBook, you probably have received a bad battery and I would recommend you to contact the store where you ordered it from to have it replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luis Fernando Cervantes López 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 51
