跳转到主内容
宏碁 Chromebooks 维修指南。
242 个问题 查看全部
I spilled soda on my Chromebook, why won't the sound work?
My bird scared me and I spilled Fanta on my earbuds and the sound stopped working, what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
Please verify if it is the earbuds that have the problem or the laptop as it is not clear from your question?
If the earbuds what is the make and model number?
If the laptop what is the model number?
完成的
添加一条评论
1个答案
I am also confused as to whether you are concerned about your earbuds (an accessory), or the actual Chromebook. Either way, it sounds like the liquid penetrated far enough into whatever device it was spilled on and damaged it to the point of it not working (if that wasn’t obvious already).
With that said, I would say you either need to replace the speakers or earbuds. If it is the Chromebook’s internal speakers, you may get lucky and be able to clean off the tabs where the speakers connect (as well as the speakers themselves if they are sticky or clearly affected by the liquid) with some isopropyl alcohol, preferably as a swab. BD sells some, for example. Just a note - this is a mere suggestion, I have not done this before. Just be sure that if you do, you do not soak the items, but gently rub off the residue. If there is still any liquid, soak it up with a cotton ball or microfiber towel.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simply Parakeets 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 219
