跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
Battery won't charge after display replacement
I successfully completed this guide but when I put everything back together and turn it on, I only see the low battery indicator (even when plugged in) I left it plugged in for several hours but I only ever see low battery. Occasionally the screen will light up with the Apple logo and show the keypad. It even registers a couple of key presses but before I can enter the passcode the iPad turns off. What is going on here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Double check if the battery connector is properly seated. I recently noticed something similar with an iPhone where the connector wasn’t 100%, but just enough for it to power on, but not to be properly detected in order for it charge.
这个答案有帮助吗?
得分 0
1条评论:
I took it to a repair shop and they confirmed it was in a boot loop. it's such a common problem with my particular model of iPad they refuse to fix them. I've since given up on it.
完成的
添加一条评论
添加你的答案
Brandon der Blatter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 31
