跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Broken screen on iMac 27 late 2013 problem with second screen
I have connected an external second screen on imac 27 late 2013 with a broken screen, but the imac does not open.  I do not see the logo and then the gray screen.  But if I isolate the broken imac screen by disconnecting its cables, then on the second screen I have a normal image and I see everything but the fans are full. Is there a way not to hear the fans? What should I do?  Thanks and sorry for my English
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your system is designed with sensors to monitor your systems health. So when you disconnect your internal display screen, SMC looses access to the sensors within it. When it does it goes into CPU Safe mode! This is done to protect your system from over-heating. Ramping up the fans RPM as well as lowering the CPU’s clocking. You can’t alter this.
Basically, you need to replace your internal display. Here’s the needed part: 27” iMac LCD Display Assembly, Apple P/N 661-7169
这个答案有帮助吗?
得分 0
3条评论:
thank you Dan
完成的
is it possible to control this problem with mac fan controller or other app?
完成的
@nikmetax - Sorry you can't really. SMC is in control! It always wins!
You have no choices here..
完成的
添加一条评论
添加你的答案
Nikos Metaxopoulos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 53
