跳转到主内容
加入维修社区 - 创建账户
The 2013 revamp of the desktop Mac series known as the Mac Pro.
PFM006 & PPN001 error in diagnostics
I have an MacPro6,1, the 2013 year model which has the kernel_task going to 900% and fans at full speed. I’ve run the diagnostics tool and it came up with the following two errors:
• PFM006 - There may be an issue with the System Management Controller (SMC)
• PPM001 - There may be an issue with the power management system
The mac powers on fine, but is extremely slow. The SSD is cleared so no software is installed, running from Big Sur from an USB is also really slow.
I’ve opened up the machine and there was a lot of dust. Cleaned out a lot and have put it back together. No change. The water indicators I’ve seen on the boards are not red, hence there is no liquid damage from what I can see. Nor can I see anything weird on the open sides of the boards.
I’ve also done the SMC reset, didn’t help either.
I got the 6 core D500 model with 16gb ram. It also has some HDMI issues from time to time, having the screen flicker (like it’s not getting a propper connection); however using thunderbolt > HDMI works fine.
Does anybody know what I can do to resolve this issue? Do I need to replace the backpanel/PSU, or is there another issue which I can look at?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
5条评论
Were you able get it fixed? I'm having exactly the same problem as well.
完成的
Please is there a solution for this now ?
完成的
Yeah, is there even a solution for this for in-home repairs?
完成的
Please I have the same issues with the Mac Pro 6,1. Pls were u able to fix it?
Struggling with the pc here. I have done almost every thing but nothing seems to help issue.
Pls share if u have any update.
Thanks
完成的
Did you check the cable which I posted on Oct 13, 2022 in this topic?
It looks like this cable can become loose over the years. Check that it is firmly in place. The cable can look like it's properly connected, but if you give it a push you may find it connects tighter.
完成的
添加一条评论
3个答案
最有帮助的答案
I think I may have figured this out. It turns out my MacPro 2013 had a loose Mainboard cable. Make sure yours isn't loose. Attached is a photo.
这个答案有帮助吗?
得分 9
6条评论:
I didn't connect the same problem with the fact that yes I had dropped my computer twice in the last 2 days. I got the same error codes. Open the back and started pressing boards back in and cable connectors in and I really don't know which one I hit but all the sudden the 250% kernel task and super fan mode stopped.
Everything's working peachy. This has nothing to do with Clean My Mac or software... The fact that happened right after a software update let me believe it was a software problem but...nope.
Some connector was unseated.
完成的
Lose cable was my problem. I thought my Mac Pro was dead. Thanks a lot!
完成的
What mainboard cable is this?
GPU cable*
完成的
spaztian,
THANK YOU! I had recently replaced the battery in my wife's macbook air (mid-2013). It was acting up so I unplugged opened it back up to unplug the battery and reinstall it. Then it was worse with the same errors you had. After reading your post, I opened it up again and found one of the cables loose. It's right next to the battery so easy to hit when changing it out. Seems to be working great now. Thanks so much!
完成的
Hi, did you unscrewed the computer and re attached the connections or how did you fixed the issue? mine does the same and one of the memory slot stopped working. thanks
完成的
显示更多的1条评论
添加一条评论
When your system encounters an issue within SMC, SMC will push the system into CPU safe mode! Basically ramping up the fan and lower the CPU’s clocking which is what you are seeing with the kernel_task going to 900% !!
This is to protect your system from over heating and is an expected reaction.
At this point your logic board has a problem with one of the sensors voltage sense lines. This really requires someone with deep skills working on 2013 Mac Pro’s to fix your logic board which is a rare skill set.
I own one (which I love) and even I don’t go this deep. I would recommend you visit an Apple Store let them fix it as they have access to the parts.
这个答案有帮助吗?
得分 2
3条评论:
I was afraid of such an answer. No way to reset/re-program the SMC chip?
完成的
@Paul Peelen - Nope! It is what it is.
Reprograming it to disregard the sensor is like turning off your fuel gage to your car just before you go on a long trip across the Australian outback with no fuel stops along the way, just not wise!
完成的
Replaced the screen. Has the same codes. Webcam cable by the fan was culprit. Tested webcam of the broken screen and all is good. Now i need another screen and return this one.
完成的
添加一条评论
I had a cable/ribbon loose. It is one the connects around the fan. Reconnecting sent the Kernel from 250% down to regular levels. If the image shows, my fingers are on both connections of the ribbon, it didn't appear loose at first, but clicked into place, then regulated itself
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Peelen 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 27
过去 30 天: 124
总计 10,886
