跳转到主内容
Catalina partition becomes unbootable and turns into "disk0s2"
I was dualbooting my MacBook with Catalina and Mavericks - install went perfectly fine, until I had to restart the computer, and discovered my Catalina partition is completely gone from the boot picker!
At first, I simply thought it was due to APFS not being recognized - however even with a Catalina install USB, it shows the Catalina partition as “disk0s2”, and I can’t write or install to it. Only the second Mavericks partition shows up. Using the diskutil list disk0 command in the terminal (lists partitions on disk0, the main drive in the computer) shows the same partition as FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF
It seems as if the data and the partition itself is still there, only it’s unable to be booted from. Now how do I boot from it? I apologize if the information given isn’t that much. Any help is really welcomed.
Edit - my Mavericks partition is still bootable. Only the Catalina partition - which doesn’t show up in the boot picker in the first place.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What is the other OS in the other partition?
完成的
@danj Mavericks. Sorry, just added it.
完成的
添加一条评论
1个答案
Sounds like you had Catalina installed and then added Mavericks which messed up the boot partition. You’ll need to see if installing Catalina again fixes things.
这个答案有帮助吗?
得分 0
6条评论:
I can't get the Catalina installer to even install to "disk0s2"...
完成的
@amatsuda223 - You'll need to setup an OS installer USB thumb drive after downloading the installer file from here How to get old versions of macOS and following this guide How to create a bootable macOS Catalina installer drive
完成的
@danj I already have a Catalina install USB - my plan being to simply reinstall Catalina. It doesn't detect the partition.
完成的
I've never tried installing an older OS-X onto a system with a newer macOS APFS release so I really don't know how to proceed without redoing the OS. I hope you have a backup ;-{
完成的
@danj I managed to find this - https://apple.stackexchange.com/question... - seems it could help, unfortunately I got lost halfway through...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
amatsuda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 277
