跳转到主内容
A cellular device manufactured in 2004 by Sony.
2 个问题 查看全部
Flashing red light on joystick
Yesterday, on my ancient but trusty T630, a red light started to flicker regularly. I don’t remember seeing this before. Today after turning it on, the light is gone again. Could someone tell me the meaning of this light? I have looked in the user manual and can not find anything!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
A likely reason, not sure if it applies to my old phone though...
完成的
添加一条评论
2个答案
已选择的解决方案
Did you charge it before turning it on today? Sounds like a low battery indication.
这个答案有帮助吗?
得分 0
添加一条评论
Hi gmantunt,
The phone is turned off and put on the charger every night. It has to be off, because for some reason it has a problem charging correctly if the phone is on. So I don’t think it would be a low battery - the battery icon didn’t indicate it anyway. I suppose it could be a glitch of some sort that resolved overnight? Anyway, I appreciate your taking the time to answer!
这个答案有帮助吗?
得分 0
1条评论:
No idea what it could be then. Well as long as the phone is working correctly there's not much to fix right?
完成的
添加一条评论
添加你的答案
Lami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 95
