跳转到主内容
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
12 个问题 查看全部
Why my laptop doesn't detect my Graphics adapter?
After I’ve cleaned the fans and replaced the paste, after one month I’ve noticed that my graphic adapter is not being read. I’ve installed my Windows when I’ve done the cleaning and also all my drivers, including the graphic one and everything went smooth, but now it says that I don’t have a GPU. What should I do?
I remember I was very gentle with every part of my laptop, when I’ve clean it, just to avoid this kind of problems.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @maricruze
What is the status of the Nvidia GPU as shown in Device Manager > Display Adapters > right click on the Nvidia entry (if it is there) > Properties > General Tab > Device status?
完成的
There's no Nvidia at the Display Adapters :(
完成的
添加一条评论
1个答案
Hi @maricruze
Check in BIOS > Advanced > Graphics Configuration and see if it is shown there.
Unfortunately the user manual (see p.72) doesn't show what the settings are.
At 9:20 minutes into a teardown video of the laptop it shows the CPU and the GPU and both are hard mounted on the motherboard so it is not a case of a loose connection
这个答案有帮助吗?
得分 0
5条评论:
It doesn't appear in the Bios either.
完成的
@maricruze
Please "Unaccept" my Answer as it didn't solve the problem.
Also please verify the model number of the laptop?
If it doesn't have any appearnaces in BIOS or Device manager the GPU has failed but this is very strange given that you only cleaned it.
Did you apply fresh thermal paste to the GPU chip as well as the CPU chip when you applied the paste when cleaning?
完成的
I did apply thermal paste to both of them, first I cleaned the old one.
My model number is: GL503VD.
完成的
@maricruze
So there is nothing at all listed in BIOS regarding the Nvidia GPU?
What does it show in Graphics Configuration?
You may have to search every menu item in BIOS just in case it is listed somewhere else. Otherwise it appears as though the GPU has failed which would be unusual as you only cleaned it along with everything else and it all works except for the GPU
完成的
I took my laptop to a service and they've told me that my GPU is dead. Thank you for all your help!
完成的
添加一条评论
添加你的答案
Elena CC 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 125
