跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Mac won't boot / Only 1diagnostic LED
Well, another case of boot failure with only the first LED (501) lit.
Actually, I’ve already tried everything that’s been recommended here.
On pin 4, 11 and 12 I measure 11,93 / 11,94 V.
Could this slightly lower voltage be the reason for the Mac failing to boot?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The case for whether a voltage is good or bad is based in tolerance. Most power circuits have anywhere from 5 to 10% tolerance, but this can vary by spec. If the reading is within the +/- % tolerance, then the voltage is good.
完成的
添加一条评论
1个答案
已选择的解决方案
Related post may help you
Won't power up and only 1 diagnostic LED
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 37
