Several isues: first only charging slowly when turned off, than..
- I did a screen replacement. - everything worked fine for days.
Than one day the phone couldn’t charge when turned on. It was very slowly charging only when turned off.
- I also noticed that sensor for light dont work when i was in a call the screen didnt turn black.
- Later i shut it down for charging. It never turned on again. It is stuck in reboot with apple logo. Reset dosen’t help.
- I have removed the screen, to check if everything is put together probably and i have found a CUT LINE which was connected to the frame. My frame is broken so it snaped the line.
- The question is: What is this line used for? in which assembly, could this be my problem? Is it repairable? How?
I think I don't know the solution, but I will try to help you as best I can.
I think your battery is the issue. Do you remember the battery health from before it stopped working? Have you used it for a long time?
Maybe you can stop the boot loop by resetting with itunes, but I think that won't fix your charging issue.
I have no idea what the cut line you're writing about does, but if your display works fine, I don't think it will be an issue.
I hope someone else will be able to help you further!
由 Elias 完成的
I think the battery was on 78% health it was also written it needs a service... But it lasted me for a whole day basicly,
with average usage (couple h), so i dont know if this is an issue...
由 jakob 完成的
It's still not bad, but it could be the issue. Have you tried restoring with itunes? Only worth it if you have a good back up, because it wil wipe your phone completely.
由 Elias 完成的
