跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Need some suggestions with my iPhone X repair! As I cant make any call
So, basically I used my phone to click some photos and video of me and my friend's inside of swimming pool, as it advertised with one the tag as water resistant upto 2 meters, so I tried it up and I barely even dived for 4 feet it stopped responding, so when I came back home and examined the phone it turned out that I can see water moisture onto back and front lenses, so I straight to the nearest repair shop, and they straight up said that water damage is not under warranty, so I choose instead to go for local repair shop personalize for apple products only, cause I ain't gonna pay half the original price and get a new iPhone.
He opened up the device and cleaned it with Isopropyl alcohol and device was ok until I tried to make a call but couldn't as the was wasn't connecting and got cancelled every time in the middle of the call with network getting reset and if I try two to three time my device would just restart itself, and also I when I receive a phone call I couldn't here the other person and the call would just disconnect and yeah,also face is just toasted as I also examined it by camera of brother phone the flood illuminator is not working as I can see only 1 infrared flash ( there should be two of em)from my brothers device using camera.
So I went up on google and started to search about issue,
Many of the guys who had same issue with inhone 6,7 and other device but not iPhone X
Told that removing the front camera housing with flex cable and also the front ear piece with flex cable and replacing them with new one the issue would get resolve and also a heads up the issue got resolve sometimes for a week or two on itself without any update and stuff .
Any suggestions what could be don't to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
For dual-layer board devices like the iPhone X, if you need to ask, water damage repair is mostly beyond you.
Water flows, so there is no way to reliably clean between the layers of the board.
The equipment or skills to properly do this kind of repair take much more than “half the original price” of the phone.
这个答案有帮助吗?
得分 2
2条评论:
FYI I have already have my motherboard or logic board whatever you wanna call it, there are no such any problem with it whatsoever as far as the guy can tell.
My only problem is:
1- can't make nor can receive em cause they just cut itself in the middle and network restart, if I try multiple time my phone would reboot.
2- flood illuminator is smoked so I can't register my face id.
Possible resolution for my problem I have came across on internet in past couple of years:
1- change the front earpiece and the flex cable.
2- change the front camera module and the flex cable.
If this don't work, as I have already reset, update the phone but nothing happened and also it get automatically all good sometimes for couple of day, idk why?.
Then,
3- change the antenna lines.
That's my conclusion I have accumulated with a bit research and public comments on different websites.
What do you think about it and do you have any suggestions please let me know.
Thanks
完成的
@MAKstyles For 1, There could be water damage between the layers of the board, especially on lower layers where RF chips are located. Separating the layers to repair is pro level work, DIY cannot do it.
For 2, Just changing probably won't work as you have to re-code the sensor flex cable.
For 3, You can't fix network restart by just replacing the antenna, it's like replacing the tires when you have an engine problem.
完成的
添加一条评论
添加你的答案
MAKstyles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
