跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
Why isn't the replacement screen fully responsive?
I replaced the screen and battery on my iphone 6s with the kit from ifixit. The battery is working very well. The screen is not as responsive as my cracked screen was. Sometimes when I tap on the screen it just doesn’t respond. Would that happen if I didn’t plug all of the cables back in firmly enough? Is it a faulty replacement screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Could be any of the two issues you describe. Best thing to do first is re-open the iPhone and check the connections, but also check the ribbon cables to make sure they didn’t got damaged during the installation. If everything is fine, you’ll have most likely received a bad screen, you contact iFixit directly for a replacement :-) they don’t read the support forums.
https://help.ifixit.com/category/133-con...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Diana Riddle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 17
