跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
133 个问题 查看全部
How to make external display active with dead internal display
I got in an a liquid damaged MBP. The internal display is not working. An external display does work but all it’s showing is the users desktop image. I need to make it the active screen so I can get into Terminal to turn off the auto-boot. I’ve forgotten how to do it. Also any hints on what to look for on the liquid damage would help. Thanks. @danj
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mayer - Did you close the lid?
Using an external keyboard and mouse you should gain access to the primary display window after you close the lid.
这个答案有帮助吗?
得分 2
3条评论:
@danj That works, Thanks. Any idea of what to look for as to the failure of the internal display?
完成的
@mayer - Likely a blown T-CON board. A common issue in this series as they run too hot!
完成的
The kid woke up and realized it was covered under his AppleCare after I cleaned it. Did do a Time Machine backup and restore his data onto a new MBP.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 105
