跳转到主内容
Wont charge even after replacement parts
Hi,
this is for the s20 series along with the note 10 series (same issue ).
I have had multiple s20s and note 10s come in for not charging. wether they dont charge at all, or will still charge but show the yellow triangle, or just dont show any current at all.
I have replaced the charge port board, 2 flex cables along with the wireless charging /nfc part along with the battery and nfc pcb connectors. I have tried multiple parts from multiple suppliers multiple times with the same results, still wont charge. About 10% of these 2 models that come in one of those 4 parts fixes the issue and all is well. the other 90% are failed. I know there is the ic chip under the metal cover up and to the right of the battery connector however haven’t dug into that yet.
anybody else run into this?
thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hey,
I have a similar problem with my Galaxy Note 10 plus. It suddenly stopped charging via cable. Also no data transfers via cable.
So naturally I immediately cleaned the USB-C port. As this did not help, I replaced the daughter/ charging port board. Still nothing.
To be clear, if I stick a cable in the charging port the phone does nothing whatsoever. Luckily the phone can be charged wireless so that's what I´m currently relying on.
I´m not an electrical engineer so I´m kind of wondering what to try next.
完成的
添加一条评论
1个答案
That happens ,you need to change the whole charging pad If the phone shows up with a temperature icon then that’s the issue
这个答案有帮助吗?
得分 0
2条评论:
what charging pad is that?
完成的
does the phone show a temperature icon inside the warning sign
完成的
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 28
总计 199
