My motherboard does not recognise one of my RAM sticks in one slot.
I have recently purchased a motherboard and CPU.
The guy i bought it from, used dual channel 2*4GB RAM in his configuration.
When I got the parts, I tried using an 8GB Stick in the first RAM slot.
The pc could not start, and it started beeping. Then I moved the RAM into the secon slot on the motherboard and the PC started working perfectly. Then i wanted to put a second RAM into the RAM slot, that was not working, but oddly, the coputer could not start, started beeping, so basically the same stuff that happened when only one stick was inserted.
I dont understand what may be the problem here.
CPU: Intel Core I3-7100
Motherboard: Gigabyte B250M-D2V
RAM: 2400MHZ Crucial RAM, that is on the list of the supported RAMS of the Motherboard.
Any help?
4条评论
Carefully read the acceptable RAM configurations. Dual channel systems usually have strict rules on 1, 2 and same / different sizes. When it ran on one stick in the 2nd slot - it recognized that's all it had: single channel of 8GB size.
由 Kevin Sargent 完成的
Does the second RAM module you tested have the same specs(speed,vendor etc.) as the first one? Have you tried loading BIOS default settings before testing?
由 Simone 完成的
@customsarge I have tested with not-supported 3000Mhz Rams from my brothers computer, and i have also ordered 2400mhz officially supported rams.
When it gets here, I will try again, but I have only one stick of it.
由 Áron Kovács 完成的
@simone_i yes, they were the same rams.
No i did not tried it before. I know that the guy i bought it from, used dual channel 4gbs of RAM. How yould y load the default BIOS settings?
由 Áron Kovács 完成的
