跳转到主内容
加入维修社区 - 创建账户
1997-2006 年生产的 TJ 系列牧马人(Wrangler)。
Doesnt switch gear, any help?
Doesn’t switch further than 2
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Assuming it’s a manual transmission, have you checked the shifting linkage to make sure it’s not broken right? If you are using the clutch and it’s shifting into 1 and 2, seems that the clutch cabling is engaging fine.
This is just an example of bushings worn or the cable out of alignment: https://mercedessource.com/problems/tran...
Basic troubleshooting for you to do:
https://axleaddict.com/auto-repair/Manua...
Next time, check those first before posting as people will want photos and such. Also state the type of transmission as that’s extremely relevant to troubleshooting/diagnosing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jack doul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 269
