Not Turning On after install of Big Sur
Hello, I have recently updated my MacBook to big sur and have not been able to turn it on since.
I have reason to believe it is a problem with the USB port not charging it or maybe the logic board.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 17
Does the backlight turn on or do you hear a startup chime when you press the power button? If you press the power button while holding the option key does it show Macintosh HD?
由 Devnol 完成的
The backlight doesn’t turn neither do I here a start up chime, I believe it might be a faulty port or logic board
由 Christian Commaille 完成的
